Hello all ---
I have a Ground Control Pro and a GCX -- just starting -- seems complcated.
I hooked it up with a midi cord that powers the GCP. As I switch thru the buttons on the GCP all of the lights work on the GCX except loop 1.
The number 1 light on the Ground Control comes on but not the light on the GCX.
If I click on button #2 (GCP) light 2 comes on both the GCP and the GCX --- and so on thru loop 8 ---- but not loop 1 -- no LED light on the GCX (but to be clear the light on the Ground Control comes on and works) --
Thoughts? Light out maybe?
Cudarea
Ground Control and GCX - Loop 1 LED
Re: Ground Control and GCX - Loop 1 LED
Check what button 1 is programmed to do...
1. Press both Setup buttons at the same time to enter Setup Mode.
2. Press the button marked Instant Access.
*What does the screen say? In order to have Instant Access button 1 control loop 1 of your GCX it should read "1 GCX-1 LOOP1".*
3. Use the Data +/- buttons to change the flashing value, use the Cursor Left/Right buttons to change which value is flashing.
4. Press either Setup button then press the Yes button to exit Setup Mode.
Let us know if you get stuck.
cool -- thanks -- got it --
