Hex Dimensions
Djon
Hex Dimensions
Post by Djon »
I’m new here :D ! I know it has already been covered, but the response info isn’t available any more. I’m trying to find the actual hex switch dimensions. Any hint/help? So far I I didn’t find online anything accurate, so was trying to google images/insta/Pinterest in order to estimate the length of it according to the rest components of known dimension. I’m still missing the height which is important cause I’m planning to attach bellow a pedaltrain.
Thank you in advance!
Marlboro05
Re: Hex Dimensions
Post by Marlboro05 »
Hi there,
It is 1 rack height which is 1.75”inches, 4.4cm high.
And some other stuff.
