GCP – JMP-1 and volume pedal
Posted: Thu Mar 04, 2010 11:44 am
GCP – JMP-1 and Volume pedal
Here is another question for you guys –
I see a number of posts for expression/volume pedals but can’t find anything that helps me directly – so here it is –
I have the GCP going into a GCX – then midi to my JMP-1 then to my G-Major 2 –
Volume pedal in pedal 1 on GCP –
Pedal 1 is “on” in GCP –
I see – as I scroll thru options for the pedal on the CGP -- that the value number adjusts from 0 to 127 on the GCP display as I move the pedal – but somewhere I think I need it to tell the JMP-1 something thru midi --- right?
Or does it need to control the G-Major (this doesn’t make sense to me because I don’t always have the G-Major on and I want the volume pedal accessible at all times) –
I just want this pedal as a simple volume control – so it should control the volume of the pre-amp (JMP-1) right??
