GCX Audio Switcher compatible with OBEL
My guitar has an OBEL. The guitar uses a stereo 1/4" jack from guitar to send/receive signal to/from effects loop and then a the mono 1/4" jack from guitar send to signal to the amp. Is there an audio switcher available that can accommodate this routing configuration? My thinking would be to use the Ground Control Pro to control the audio switcher. I'm sure there are configurations out there with OBEL - hoping someone can help point me in right direction. Thanks! -rk72
Re: GCX Audio Switcher compatible with OBEL
Really this setup isn't any different as far as effects switching goes... your Effects Send would go to the switcher, your effects would go into the loops of the switcher, then the Out of the Switcher would go to your Effects Return. The only complication is breaking out the TRS connection to be friendly with the TS (Mono) jacks that the Switcher, and likely all the pedals, have.
If you tell us you full signal path, I'm sure we could help a bit better to find exactly what would suit your needs.
