GCP & GCX with Avid Eleven Rack
ChrisParry
Post by ChrisParry »
Hi Guys,
I have the GCP and GCX.
It is setup as 4 banks and 8 IA.
Can I also use the same GCP to control an Avid Eleven Rack system but using some of the used banks and therefore use the IA buttons associated with the 11R within those banks.
And not have to reconfigure when I switch from using the 11R to the GCX?
Hope it makes sense
Chris
ChrisParry
Re: GCP & GCX with Avid Eleven Rack
I understand I will have to change the midi channel on the 11R to an unused one
