GCP & HX Effects | Power Supply
ChrisParry
Post by ChrisParry »
Is it possible to control the HX Effects with a GCP
8 IA Buttons for the 8 blocks
4 Snapshots
Up & Down to change presets
Also suggestions for a power supply for the GCP. I have a GCX which powers it usually with the rack system but want to use it on it's own with the HX Effects.
Is it possible to have the GCP configured to work when plugged into the GCX and the rack system, then use at another time on it's own with HX Effects without having to reconfigure each time.
ChrisParry
Re: GCP & HX Effects | Power Supply
Can anyone assist with the HX effects issue being controlled by GCP?
SlapHand
Post by SlapHand »
Hi there!
I have an HX/FX in my rack and controlled by a GCP.
You will not be able to jump between snapshots. You can switch presets and the snapshot you had up when saving that preset will be activated.
—- SlapHand—-
