Why not allowing "Program Change" on GCX??
alexglvr
Post by alexglvr »
I have a G-system and I would like to use it to command a GCX switcher.
Unfortunatly, when a preset is selected, the Gsys can only send "Program Change" midi oder.
But the GCX only support "Control Change" commands...
Can we imagine a software update allowing "Prog Change"?
(It will also be usefull for the owners with other midi controllers. It would avoid sending 8 "Control change" orders...)
Let's imagine, 128 presets responding to "Program Change" oders:
Preset 1 : PG1
Preset2 : PG2
...with the possibility to store in Each preset:
- the wanted state for each loop
- the type of commutation for each loop (latch/momentary)
It could be nice !!!
Alex
Re: Why not allowing "Program Change" on GCX??
There are no plans to make the GCX respond to MIDI Program Changes as the reality of it would actually require quite extensive hardware changes.
