Not saving instant access state with presets
Posted: Thu Mar 18, 2010 1:01 pm
by gbevin
I would like to not saving the state of the instant access buttons with a preset. I really want them to behave totally independently while using the bank and 1-4 buttons to select programs. Is this possible?
Geert
Re: Not saving instant access state with presets
Posted: Fri Mar 19, 2010 9:42 am
You can do this if the Instant Access buttons are controlling GCX loops by disabling the GCX within your Ground Control Pro presets. This cannot be done if you have reprogrammed the Instant Access buttons for something other than GCX loops.
Posted: Fri Mar 19, 2010 9:45 am
by gbevin
That's a major bummer! This means that when I switch presets, the state of what I control with the instant buttons doesn't correspond to what the buttons show. What is sent out when GCX loops are being used? Can I get the data through MIDI also?
Posted: Fri Mar 19, 2010 9:58 am
Lets back up here then... tell me what you are controlling.
Posted: Fri Mar 19, 2010 10:54 am
by gbevin
I'm using the instant access buttons to send CC messages that arrive at my computer to turn effects, virtual instruments, plugin, ... on or off. These should be independent from the presets. I use the presets to change my global guitar sounds, however this is independent from the instant access buttons. I don't care which CC the instant access buttons send, as long as it's a clearly different value for on and off, and they work totally independently from the presets.
Posted: Fri Mar 19, 2010 11:34 am
by gbevin
I tried what you suggested with the GCX loops and disabling them for the presets, and I think this will work. Thanks!
