NO signal from GCX
NO signal from GCX
Hello! Today my gcx switcher has decided to not work more.
When I press the on/off botton, it sounds with the usual click, with the light/led presentation from 1 to 8 and nothing else. It stays without the active red light on... And also the gcp doesn't work... What could be? Anyone of you have had the same problem? Thanks
Re: NO signal from GCX
Does your Ground Control Pro power on, or does it stay dark? Have you tried a different MIDI cable? It sounds like either your GCP isn't getting power, or MIDI data isn't reaching the GCX, both of which would point to a bad MIDI cable as the most likely culprit.
