GCP Power over MIDI Out port
Felonius Punk
Post by Felonius Punk »
Hi, noob here.
I have a Ground Control Pro and I want to use a MIDI Solutions 1-In/4-Thru MIDI router. The MIDI router will take power over MIDI. Does the GCP sent power over MIDI throug the out port?
dystrust
Re: GCP Power over MIDI Out port
Post by dystrust »
The Ground Control Pro does not send power via the MIDI out port. The GCX does send power over pins 1 & 3 of the 'pedal in' port.
