Control Switcher help
StevenMikel
Post by StevenMikel »
I have a Marshall TSL100,a Rocktron Replifex, a Rocktron Midi Mate and, a Control Switcher. I hooked the Control Switcher up to the amp and got it to change channels but ,not in the way I want it to .I want to be able to change channels and turn the FX loop of and on(I'll leave the reverb on all of the time) and change presets on the Replifex with the Midi Mate, the Replifex is going into the front of the amp. I'm confused about how to set the functions(normal, reverse ,momentary) of the switches of the Control Switcher. Should the switch for the clean channel set to normal and the one for crunch and lead set momentary ?
Hooking it all up. Do I go from the midi out of the Midi Mate to the midi in of the Control Switcher then out to the Replifex or, do I go to the midi in of the Replifex then out to the Control Switcher?
Thanks in advance for any help.
Mike8083
Re: Control Switcher help
Post by Mike8083 »
Does your Marshall use a DIN plug for switching or 1/4" plug? I would get the patchmate to work with the intelifex first. Then you should be able to add the switcher and select which channel is active for which preset. Hope this helps. If not, i need more info. Your patchmate will send out program change info and I believe the switcher will work with that. If you dont want the channels to change with each preset, then you will have to assign a CC on the patchmate for each channel of the amp
Marlboro05
Post by Marlboro05 »
Hi Steven,
You need this cable
https://reverb.com/au/item/39940907-rjm ... p4EALw_wcB
I’ll see if I can work out which wires need to go where, you may need to get a 6 pin midi plug for the amplifier end.
And some other stuff.
Marlboro05
Hi Steven,
You could make your own cable as so:
5 pin midi plug. 6 pin midi plug. Function
Pin 1. To. Pin 1. Clean-Gain
Pin 2. To. Pin 6. Common
Pin 3. To. Pin 2. Crunch-Lead
Pin 4. To. Pin 4. Reverb
Pin 5. To. Pin 5. Effects
Not sure if they are Normal, Momentary or Latched, have a muck around after making the cable.
Marlboro05
You can check this here for 6 pin locations
https://music-electronics-forum.com/for ... h-problems
And in the Control Switcher manual, page 4 for the 5 pin locations
http://www.voodoolab.com/manuals/contro ... manual.pdf
StevenMikel
Marlboro05 wrote:
Fri Jun 25, 2021 9:34 pm
Hi Steven,
You need this cable
I have a cable that I got from Best-Tronics,it does what it's supposed to do
Marlboro05
Awesome, good *👌
They make the cables that RJM used to.
Marlboro05
Did you get your rack set up?
StevenMikel
Marlboro05 wrote:
Tue Jun 29, 2021 9:57 pm
Not yet. The problem I'm having with the control switcher is, figuring out how to set the switches(normal,momentary etc...). I think I know how they need to be set but,haven't had time to sit down and do it.
Marlboro05
The amp mode switches are momentary(clean, crunch & lead), reverb and effects are latching and all should be normal from looking at the pedal schematic.
