GCX/noise gate/effects pedals connections
Hello there,
My connections are almost done but it there is still a problem with the loop 5 to 8 which are not connected with the noise gate (Fortin Zull) and as you can see, it remains an out on the splitter box (Fortin Zull)
What would be the solution to connect the last Out of the splitter box, the loop 5 of the GCX and the Send of the second loop of the amp ?
I don't know if I'm right or not concerning my logic here.. Some people told me they don't understand why I want to use the second effect loop pf the amp (Diezel Herbert)..
The aim of the configuration is to put the effects which are in the loop 1 to 4 before the preamp and the others (loop 5 to 8) in an effect loop.
But the noise gate is supposed to be placed in the effect loop.
So, what's the solution ? Do I need to the "switchable loop" too for what I want to do or not ?
Hope you can help me.
Thanks for reading me.
Erwan
