How do I remove the GCPs Rubber Feet?
Posted: Sat Mar 27, 2010 5:14 pm
by simspace
Hi, I need to velcro my GCP to my pedalboard.
I've tried unscrewing the rubber feet, but the screws just keep turning. They don't come out.
Can someone please tell me how to remove the GCPs rubber feet?
Chris Simeone
http://www.u2act.com
Re: How do I remove the GCPs Rubber Feet?
Posted: Sun Mar 28, 2010 8:27 am
by Jeremy
If I remember correctly, I had to remove the top to access some nuts that are located on the inside of the chassis.
Posted: Sun Mar 28, 2010 1:06 pm
by simspace
Thanks for the reply!
I removed the bottom screws, but it seem the top and bottom are some how locked together almost like I have to pull something apart. But I can't figure out how. I was afraid to use brute force. That does not seem like a smart idea.
Any ideas how to separate the top and bottom?
Chris
www.u2act.com
Posted: Mon Mar 29, 2010 9:17 am
You must also remove the four 5/64 Hex head screws from the top of the Ground Control Pro in addition to the six #2 Philips head screws on the bottom in order to access the Nylon Stop nuts that are preventing you from removing the feet.
Posted: Mon Mar 29, 2010 11:38 am
by simspace
Thanks John,
I thought that might be the case (no pun intended), but I wanted to make sure.
Anything I need to be aware of about the internals when opening it up? Or is it pretty straight forward?
Chris Simeone
Posted: Wed Apr 07, 2010 10:45 am
It should be fairly straight forward. There is nothing that will jump out of the chassis when you open it up unless you got one of the ones I put a magic shop trick snake into. :twisted:
SPROING! AHHHHH!
Posted: Wed Apr 07, 2010 10:50 am
by simspace
LOL... I used to have one of those when I was a kid. Thanks for letting me know! :o
