Footswitch cable from amp to GCX
I am having difficulties finding a cable to go from my GCX to my new Madison Prophecy amp for channel / effects switching. I have gone to Jerry at FJA Mods and he couldn't help me, either. The Prophecy has a 3-button footswitch and 2 cables to the amp. One button is for the clean/crunch channel switching, one button is for the gain setting once the crunch channel is kicked in, and the third button is to toggle the onboard effects on/off. Do I need a special cable or is there a way to hook this up to the GCX with regular cables? I had a XXX with the special cable, so I know it was split between two GCX channels, but what do I do now? I tried using 2 regular 1/4" cables from the amp to the GCX, but I don't have the option to select between the dirty and high gain channels. It only goes from clean to high gain.
Re: Footswitch cable from amp to GCX
Likely what you need in an Insert Cable for the dual function jack and a regular mono cable for the effects bypass jack. This will require a total of three GCX loops to have full control. I assume these are 1/4" jacks on the amp and that one is for the channels and the other is for the effects?
That is a correct assumption, John. 1/4" jacks and one for effects on/off, one for channel clean/dirty/gain.
Looks like I need to pick up another GCX as I only had room for 2. Lucky me!
Thanks for the help!
