Instant Access Buttons?
drolaw
Post by drolaw »
Anyone know how to assigned IA buttons so they use the same GCX loop (in my case loop 1 which is an H9 pedal) but different user preset on the H9?
I'm using the GCP with a GCX and cannot determine how I can assigned instant access buttons 1 -4 to use the same pedal (H9 pedal from GCX Loop1) but different effect channels from the H9 pedal.
Example.
I'm in the 4 preset mode and have my H9 connected to the GCX in loop 1. What I would like to do is assign the first 4 instant access buttons as follows:
- Instant access button 1 - control H9 effect 96 (96 is the user preset on the H9)
- Instant access button 2 - control H9 effect 97 (97 is the user present on the H9)
- Instant access button 3 - control H9 effect 98 (98 is the user present on the H9)
- Instant access button 4 - control H9 effect 99 (99 is the user present on the H9)
I've been able to assigned access IA button 2 to control GCX loop 1 (the H9) but I cannot figure out how to make button 1 use the H9 with effect #96 and button 2 use the H9 with effect #97. Also, If I program any of the present to call up GCX Loop 1 all 4 IA buttons are active. My hope was to use the IA as an On/Off and not all be active at the same time.
Any help would be appreciated.
Here is a layout of what I'm trying to accomplish:
ground control pro layout:
- 4 preset mode with instant access mode
-- 1 GCX Loop 1 (H9 with effect preset 96 Slap back delay)
-- 2 GCX Loop 1 (H9 with effect preset 97 MicoPitch #1)
-- 3 GCX Loop 1 (H9 with effect preset 98 MicroPitch #2)
-- 4 GCX Loop 1 (H9 with effect preset 99 Detune effect)
-- 5 GCX Loop 5 Delay (Boss Pedal short delay)
-- 6 GCX Loop 6 Delay (Boss Pedal Long delay)
-- 7 GCX Loop 7 MXR EQ Pedal
-- 8 GCX Loop 8 MXR SmartGate
