Dual Rectifier custom cable for Control Switcher
AttitudeEra
Post by AttitudeEra »
Hi guys
I know I can use the 4 individual jacks which I have been doing, but to tidy things up a bit I’d like to look at using a DIN cable to the amp instead.
Dual Rec has 3 channels and a solo boost (not fussed about FX loop off/on) and has a 7 pin DIN port.
Does anyone have any info on what I’d need to have made? I’m assuming 7 pin to 5 pin DIN cable but is there anything else I need to know?
