Control Switcher and Mezzabarba Skill
Posted: Thu Jun 30, 2022 1:54 pm
Curious if there's a list of modern amps that are rather plug and play using the multi jack on the switcher into a midi shaped but non midi jack on some modern amps footswitch jack. Example just picked up a Mezzabarba Skill combo that uses a midi jack for its footswitch but it is "not" a midi port. Pin #3 is the ground pin, while 1-2-4-5 are for amp functions on/off, so assuming midi cable from amp footswitch jack to the Voodoo multi jack switcher input and I'm good to go, no special fan out 1/4" cable required....???
