GCX switcher problem
Adam E
Post by Adam E »
I just got back from vacation so my rig sat dormant for 10 days. I went to play and my gcx switcher isn't wanting to power up, yet it's still sending power and signal to my ground control unit. then i looked back and the active and loop lights aren't coming on at all. any ideas what the problem could be?
Re: GCX switcher problem
Does the Active LED on the GCX flash when preset buttons are pushed on the Ground Control? Is the GCX currently enabled in Expanders under Setup Mode?
Adam E
Post by Adam E »
ok so im not entirely sure what happened, but i tried a different midi cable running out to the ground control and its working just fine now. thanks for your help anyway.
