changing channels
Posted: Fri May 28, 2010 2:46 pm
by maddface
How do you setup gcx & gcp with a mesa triple rectifier to change channels? I know there is a little trick saying the amp defaults to channel 2.
Thanks a bunch, great costumer service!
Re: changing channels
Posted: Fri May 28, 2010 4:07 pm
On the 3 channel Dual and Triple Rectifiers you can get away with using only two loops to control the three channels. The Out/N.C of one GCX Loop will connect to the Channel 1 External Switching jack, and the Out/N.O. of the other GCX Loop will connect to the Channel 3 External Switching jack. It is important that you do not connect any other cables to any of the other jacks on these two GCX Loops.
Posted: Fri May 28, 2010 4:13 pm
by maddface
so when programming call up loop for channel 1 and 3 and do nothing for channel 2 correct?
