Axe Fx Special Set up Feature
DF400
Post by DF400 »
Any play to include this in a future firmware update? It would be a major help!
Re: Axe Fx Special Set up Feature
There is no plan currently to add a default setup for the Axe-FX. Unless you use the Axe-FX with no other gear and only use the factory patches, a default template would be of little use. I hope that helps!
DF400
Post by DF400 »
Thanks for your reply John. I just was feeling a little left out with the Line 6 and other templates. Makes sense though, since the sample presets do little good for me.
