hello... again..
Im totally new at this. so, here I go again.
I´ve got the gcx and a ground control. and also an TC M300.
how do I get those to speak to eachother? I´ve just reset both the GCX and the M300.
it is those midi-things that Ive dont understand....
Need help with MIDI on the GCX
Re: Need help with MIDI on the GCX
The default start up condition for the Ground Control Pro is that the presets will send Program Changes on MIDI channel 1. You will want to set your M300 to receive on MIDI channel 1, and enable the GCX within the Ground Control Pro. This will get you started and ready to start writing your own Ground Control Pro presets. Good Luck!
