switching amp fx loops
Posted: Thu Jun 04, 2009 1:39 am
by sasquatch
hi. my problem is i use two amps and want to use the same fx chain on both(at seperate times). i want to be able to assign which amp has the active loop, and still send a return signal to the other. i've figured it out, but it takes four loops of the gcx to do so. as i do alot of improvisation i would like to be able to do this as an instant access switch, but four switches at once is a bit impractical. also i would like to know how it works for presets if im using two ground controls so i have 16 instant access switches. cheers
Re: switching amp fx loops
Posted: Thu Jun 04, 2009 2:54 am
by Trueman
http://www.voodoolab.com/gcxdiagrams/bl ... heet_p.pdf
Write down your signal path on here and post it for us.
Posted: Fri Jun 05, 2009 7:52 pm
by sasquatch
- blank_gcx_worksheet_p.jpg (196.79 KiB) Viewed 7234 times
- _gcx_FX LOOP SWITCHING_p.jpg (201.4 KiB) Viewed 7236 times
here is my diagram. i have two gcx, a ground control. amps are mesa stiletto ace and mesa electra dyne. half the pedals are in front of the amp, some in loop. like i said i want to switch which amp is using the loop fx, but the other loop must return. the whammy is being controlled midi by the switcher. i have considered using a pedal switcher for the fx before the amp, but want to keep as much off the floor as possible. the way i have shown, will work but, is completely impractical as i would need to hit all four loops at once. i want to change fx loops without using presets on the ground control.
