Hello,
When there are no loop led's
On, is the guitar signal going
Straight thru from guitar input
To last loop output. If so why
Can't I hear hear my straight
Uneffected signal?
Gcx bypass mode
Re: Gcx bypass mode
When a GCX Loop is bypassed (LED Off), Its In is connected directly to the Out of the same GCX Loop. If you want a series chain of multiple GCX loops you will need to connect the Out of each GCX Loop to the In of the next GCX Loop with a short patch cable.
