pedal switcher as instant access
sasquatch
Post by sasquatch »
hi again. i know it is possible to connect a pedal switcher to be controlled by the cround control, and that the IA switches on the ground control can be programmed to use any loop from multiple switchers. can the loops on the pedal switcher be programmed to work as instant access switches for GCX units?
stilwel
Re: pedal switcher as instant access
Post by stilwel »
I'm pretty sure the answer to this is no.
The VL Pedal Switcher acts more like 1/2 of a GCX rather than a GC Pro.
I don't believe it sends out any MIDI commands when you step on it's switches.
borehead
Post by borehead »
Do you mean if the Ground Control Pro can call up instant switches on a pedal switcher? In that case, yes.
You will find the Pedal Switchers under "Expanders" on the GCP.
You can assign any switch on a PS to work as a instant access.
Hope it answers the question.
/Johan
Trueman
Post by Trueman »
+1 This is the correct answer. Good to see you on here Stilwel. You've been very helpful on HRI in regards to the M13. Im having trouble uploading the 1.07 software though :? :?
stilwel wrote:I'm pretty sure the answer to this is no.
The VL Pedal Switcher ats more like 1/2 of a GCX rather than a GC Pro.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
