configuring stereo output
Posted: Sun Oct 17, 2010 11:13 am
Hello,
I have the standard GCX and woukd like to connect the following preamps and effect racks.
-Custom Two channel preamp with odd guitar input and outputs. There is one guitar input for both channels. There is one preamp output for each channel. There is no internal channel switching. Both preamp outputs would have to remain active going into the GCX.
-Hughes and kettner blues master preamp. One guitar input and one preamp output.
-ADA TFX4 effects unit. One guitar input. Mono or stereo output. I would like to use the stereo output on this unit.
-Rocktron Intellifex. mono or stereo input. Stereo output. I would like to use the stereo output.
- Pedals. I'm hoping to have at least one or two loops for a few pedals. MXR carbon copy and an eventide pitchfactor. If on the same loop that's OK as the will sit on top of my rack and I can true bypass either if needed.
- Stereo power amp two inputs and two outputs.
I have a wah, overdrive, tuner and compressor in front pf the preamp not that that has any bearing on the GCX setup.
My issues.
-I would like to always have a preamp signal going to eack left and right input of the power amp even without effects engaged.
-Need the GCX to be able to switch between the three preamps. As said earlier the custom preamp has no switching and will have two mono preamp outputs that will always be active. I'll have to bypass them for switching.
- The TFX4 has only a mono input. How can I configure this so that when engaged the unused stereo side doen't bleed thru as the stero out from te TFX$ is what I would want.
-The intellifex has a stereo input that I would like to use as I'm thinking the effects may be more intense than inputing a mono signal.
My general thoughts are I could always run a mono signal into both effects units as they have the ability to output a stereo signal from a mono input. I would always have to have the preamps going passing trough the effects to get the stereo output. Is it possible to have the signal split to two from each preamp so that I would have stereo output without going through the effects? If so then how can I configure the tfx4 with one mono input to bypass one of the signals while I use it's stereo outputs. This is probably my biggest hurdle as I would love to be able to go straight preamp in stereo at times.
If anyone out there can offer any guidance on this setup I would appreciate it very much.
Best Regards,
Mark
My issues.
Best Regards,
Mark
