changing amp channels
gibson daft
Post by gibson daft »
hi sorry if this question has been answerd before, how would i be able to change the channel on my orange rockerverb 50 using the gcx and ground control, im aware that jim root does this via the ground control but have no idea how its done. thanks
Re: changing amp channels
You can control the channel A/B as well as turn the reverb on and off using two GCX loops. Connect either the Send/N.C. or the Out/N.O. of any unused GCX loops to the Channel and Reverb jacks on the back of the amp using standard mono instrument or speaker cable.
This amp can also be controlled the same way with a Control Switcher.
