Y cable for wet / dry setup?
John823
Post by John823 »
Sorry if this is a remedial question... Im trying to set up two amps as a wet/dry rig. I noticed in the GCX sample diagrams that a Y cable was used to split the line signal. I tried this with a split TRS cable that I was using to connect my expression pedal but only one channel came through. Is this the wrong type of Y cable? I've searched around and cant seem to find anything else. Is the solution simply soldering two TS cables to one connector?
Re: Y cable for wet / dry setup?
What you are describing having used is what is known as an Insert Cable. A "Y Cable" provides a way to split a mono source out to two mono destinations. the cable you need for this will have mono ends at all three points.
John823
Post by John823 »
Ahh! Yes, thank you, that helps tremendously.
