Two Amps Phasing
Two Amps Phasing
If I use two different amps a Plexi Marshall and a old 64 Fender,will there be any problems with phasing, since one pushes in and the Fender pushes out.
Re: Two Amps Phasing
Quick answer without knowing what else you are using: You can reverse the + and - connection to the speaker or cabinet on one of the amps.
