Tap tempo switch for GCP & G Major 2
Posted: Sun Mar 20, 2011 11:23 am
by peepee
John, please could you PM me the schematic for the latching tap tempo switch?
Many thanks.
Re: Tap tempo switch for GCP & G Major 2
Posted: Mon Mar 21, 2011 9:37 am
PM sent
Posted: Mon Mar 21, 2011 9:42 am
by peepee
Thank you, John, much appreciated.
Posted: Tue Mar 29, 2011 1:43 pm
by planethood
Did you make a tap tempo switch yet? Did it work for you through one of the expression ports with your GMajor 2?
Posted: Tue Mar 29, 2011 2:55 pm
by peepee
Hi, yes, made the switch - very simple to do - and it works beautifully with the G Major 2.
It's a very small pedal and I have it beside the Ground Control Pro on my pedal board (I previously controlled tap tempo with one of the Instant Access buttons but needed to free it for other duties), connected to Expr. Pedal input 2, Pedal input 1 being for the Ernie Ball volume pedal used as an expression pedal.
It's been really easy to set up the parameters which are controlled by tap tempo within the G Major 2 patches and I now have the level of control over everything that I wanted, so a real success.
Thanks again to John!
Posted: Mon May 09, 2011 1:52 am
by PosterBoy
I think the schematic is something I might need too John if that's possible.
I tried using a Boss FS-5U from Pedal 1 for Tap Tempo on my Axe Fx and it didn't work, someone told me it was because the pedal inputs are TRS not mono. Is that the case?
Posted: Mon May 09, 2011 11:48 am
PosterBoy wrote:I think the schematic is something I might need too John if that's possible.
PM Sent...
This is specifically for connecting to the Ground Control Pro... if you are connecting your Tempo switch directly to your AxeFX then you will want to contact Fractal to find what type of switch is needed.
Posted: Tue May 17, 2011 11:23 pm
by John823
Hi John,
Could you send me that as well?
Thanks in advance
Posted: Wed May 18, 2011 10:07 am
PM sent.
