GCX Switcher & Ground Control (Not Pro) Question?
Posted: Mon Jun 29, 2009 5:43 pm
by lespaul
New to the forum and also new to the rack thing... :oops:
This might be a dumb question...I recently purchased an older GCX and GC unit. Can the GC send CC#'s and does it offer any Instant Access buttons? I also picked up a TC G-Major 2 and according to the owner's manual...it is best to run it through a Serial loop. All the loops in the GCX is serial and not parallel, right? :?
Hope someone would chime in, thanks in advance.
Tony
Re: GCX Switcher & Ground Control (Not Pro) Question?
Posted: Mon Jun 29, 2009 6:02 pm
by Josh Fiden
lespaul wrote:Hi,
Tony
The original Ground Control can be setup to have 6 instant access buttons to send cc messages. It will not save the state of the IA buttons per preset, that feature was added to the PRO version. Running effects in parallel requires a mixer.
Josh Fiden
Founder / CEO
Posted: Mon Jun 29, 2009 7:34 pm
by lespaul
Josh Fiden wrote:
lespaul wrote:Hi,
Tony
Josh Fiden
Founder / CEO
Thanks for your reply, Josh
There're couple of features on the G-Major 2 like Boost function for a preset and channel switching using relay by sending a cc message. So I guess it is possible to take advantage of these features with the original GC?
I'm not planning to run the G-Major in parallel...So I would simply use loop 4 for left send/return and loop 8 for right send/return. That's connecting in serial, correct? :oops:
My signal chain:-
Guitar->Soldano X88R Preamp->GCX->VHT 2/50/2 Power Amp
Loop 1 (Hush)
Loop 2 (Phaser)
Loop 3 (Flanger)
Loop 4 (Gmaj 2 Left)
Loop 5 (Channel 1 Preamp)
Loop 6 (Channel 2 Preamp)
Loop 7 (Channel 3 Preamp)
Loop 8 (Gmaj 2 right)
thanks
Tony
Posted: Mon Jun 29, 2009 10:41 pm
by Josh Fiden
My signal chain:-
Loop 1 (Hush)
Loop 2 (Phaser)
Loop 3 (Flanger)
thanks
Tony
The term is series, not serial, although you could refer to it as connecting devices in a serial manner. Series means that the output of one device is connected to the input of the next, and so on. To connect in parallel, you add the outputs together with a mixer. Commonly you see amps with parallel effect loops. These are combining the output of the effect (going to the amp effect return) with the original preamp signal.
I assume the phaser and flanger are going in front of the X99. The preamp output goes to the in's of loops 4 & 8, the out's of those loops go to the power amp.
Incidentally, I just replaced the faceplate on my 2/50/2 with the new Fryette logo. It's a great power amp and I wouldn't want any inadvertent confusion.
Josh Fiden
Founder / CEO
Posted: Tue Jun 30, 2009 5:48 pm
by lespaul
Josh Fiden wrote: I assume the phaser and flanger are going in front of the X99. The preamp output goes to the in's of loops 4 & 8, the out's of those loops go to the power amp.
Hey Josh,
Thanks for the heads up...I never thought of wiring the Phaser & Flanger in the GCX this way. :oops: I was going from Guitar straight into Preamp->GCX->Hush (L1)->Phaser(L2)->Flanger(L3).... I thought both Phaser & Flanger sounded weird in loop 2 & loop 3. :? So I ended up removing them from the GCX all together and had both pedals setup on the floor in front. Ex. Guitar->Wah->Phaser->Flanger to Rack....
So, are you suggesting I should wire my rig like this?
Guitar->in GCX out ->
Loop 1 (Phaser)->Loop 2 (Flanger)->Soldano X88R->
Loop 3 (Hush) Left out to Loop 4 in (Gmaj 2 Left),
(Hush) Right out to Loop 8 in (Gmaj 2 right)
the out's of loops 4 & 8 go to the power amp (L/R)
Channel Switching
Please advise,
Tony
Posted: Wed Jul 01, 2009 5:30 pm
by lespaul
Anyone?
Tony
Posted: Wed Jul 01, 2009 11:04 pm
by Josh Fiden
Yes, that's okay. Try it!
Posted: Thu Jul 02, 2009 3:49 pm
by lespaul
Josh Fiden wrote:Yes, that's okay. Try it!
Okay Josh, thanks for your reply.
I'll give it a try and will post back.
Tony
Posted: Thu Jul 02, 2009 3:50 pm
by lespaul
Tony
