Tap tempo for Lexicon MX200?
John823
Post by John823 »
Has anyone had any success with setting up tap tempo for the mx200? Im having trouble figuring it out. I'm using a GCP & GCX.
Re: Tap tempo for Lexicon MX200?
It looks like you have two individual tempo possibilities. Tempo for Processor 1 is controlled using Control Change 17 and Tempo for Processor 2 is controlled using Control Change 24. Have you set up any of your Ground Control Pro Instant Access buttons to either of these Control Change messages?
John823
Post by John823 »
Thank you so much John.. I went back through and double checked. Somehow I still had the CC messages still set up for the unit that the lexicon replaced.
