Best GCX/GCP Signal Path?
paul_haga
Post by paul_haga »
Hello! Since I'm fairly new to the Ground Control system, I'm wondering if anyone has any tips or pointers on setting up my signal path thru the GCX. Is it the same as if you were running pedals on your pedalboard?
I plan to use the 8 instant access switches to control each pedal independently as well as set up the 4-preset/bank to create specific patches. Here are the pedals and rack units I'm working with:
Boss SD-1 (Keeley)
Korg A3
Eventide ModFactor
Eventide TimeFactor
Eventide Space
EHX LPB-1 Boost
EHX Holy Grail Reverb
Any thoughts would be much appreciated.
-Paul
Re: Best GCX/GCP Signal Path?
The signal path would be the same as you would route your devices normally... the GCX does not necessarily change this. If these devices will all be in series in front of your amp then you would run each Loop Out to the Next Loop In and run the Out of Loop 7 to the input of your amp.
