I had my ground control switching all my pedals in the rack cleanly finally after rewiring everything with george l's.
I recently received a custom pedalboard from pedalboards.com, once I plugged in through the pedalboard I had a lot of humming, so I disconnected the pedal board, and now when I plug in the ground control it does not switch the gcx anymore......
Thoughts?
Ground control
Re: Ground control
Not too sure... your audio connections cannot prevent the GCX from responding to the Ground Control Pro. Is the Ground Control Pro receiving phantom power from the GCX? Is the Active LED on the GCX on? Does the Active LED flash when you press buttons on the Ground Control Pro?
Re: Ground control
Yes, yes, and yes, only issue now is that loop 8....
Not much you can do from there.
