the rack set up
Posted: Sat Jun 18, 2011 11:32 am
by Bahamafornian
still trying to get te slight hum sorted out, i live i the Bahamas, so its not so easy just to send this out and have it checked and finished by a pro, however that is where i am at,....
Re: the rack set up
Posted: Tue Jun 21, 2011 2:18 pm
Dude... everybody knows that gear hums in the Bahamas. You can't have such fine rum and awesome weather AND gear that doesn't hum!
Re: the rack set up
Posted: Thu Jun 23, 2011 5:28 am
by Bahamafornian
Valid point!
Hum is gone, just have loop 8 issues, when engaged the volume drops off, and won't switch back occasionally, turn off a reset then it's fine.
Re: the rack set up
Posted: Thu Jun 23, 2011 5:16 pm
What do you have in GCX Loop 8? Do you get the same problem if you run a cable from GCX Loop 8 Send to GCX Loop 8 Return?
