Modifying Instant Access?
chagmaier
Post by chagmaier »
I am using the Ground Control Pro with the Eleven Rack. I would like to use an IA button to change certain parameters...not a problem, right? Sure, point the IA button to the delay setting...but IA sends either 0, or 127. I want to choose my HI and LOW values to send with the CC. IE changing between to delay settings (ms.) Can this be done?
Re: Modifying Instant Access?
The data value that the Instant Access buttons send cannot be edited, they are fixed as toggle switches for on/off control.
