Engl E530, Peavey 6505+, GCX
Posted: Tue Oct 04, 2011 9:28 pm
by rp108
So I am thinking about running an Engl E530 preamp into my Peavey 6505+ for the power section. How would you recommend using this with the GCX?
Re: Engl E530, Peavey 6505+, GCX
Posted: Wed Oct 05, 2011 11:27 am
Will you be switching between the two preamp sections or will you now just be running the Engl preamp?
Posted: Wed Oct 05, 2011 9:16 pm
by rp108
Just the Engl preamp for now.
Posted: Thu Oct 06, 2011 9:28 am
There is no real need to involve the GCX if you will be always using the Engl preamp in this case. Simply connect your guitar to the instrument input of the Engl preamp, then connect its output to the effect return on the 6505+... have you done this already and had some sort of trouble?
Posted: Thu Oct 06, 2011 11:45 am
by rp108
How do you feed all the effects post preamp then?
I figured it would be something like this:
Engl -> gcx loop 1
Delay -> gcx loop 2
Reverb -> gcx loop 3 -> out goes to loop return on 6505+
I should mention, I haven't tried the setup yet. Preamp should be here soon.
Posted: Thu Oct 06, 2011 12:25 pm
by domct203
Simply insert the GCX between the Preamp and Poweramp (post preamp / pre poweramp). Connect the preamp's output to the IN of a GCX loop, then connect the OUT of the last used GCX loop to your poweramp.
Have you looked at any of the connection examples on the GCX product page?
http://www.voodoolab.com/gcx.htm
The GCX is extremely versatile, you could even put some loops before the preamp as well.
Dom
Posted: Thu Oct 06, 2011 2:53 pm
I didn't know you had any effects ;)
