Ground Control Pro acting weird
Hi I have a GCP and occasionally it starts acting weird. The letters on the screen start going all funny and the loops aren't lighting up when I engage. sometimes they will on the GCP and then sometimes loop 1 on the GCX doesn't work. I have to keep reseting which is a pain and this time it hasn't fixed it.
Re: Ground Control Pro acting weird
Check your MIDI cable and the connections. The Ground Control Pro MIDI Out is a 7 Pin jack and it is possible to force a 5 Pin connector into this jack.
Another test would be to power the Ground Control Pro with no MIDI cables connected using the supplied adapter to find if there is a problem with the Ground Control Pro itself.
Let us know what you find.
I do have the same problem, the GPC isn't connected to any midi cable and the display looks weird, i can not read from it because of this... what can i do? where can i send you an image of this issue?
You can attach an image to a post using the "Img" link up top, second one in from the right.
