Page 1 of 2
Using two amplifiers simultaneously !!!!Help Me JOHN !!!!!!!
Posted: Fri Jan 06, 2012 5:53 am
by Marcus
Someone could help me telling where I can put the second amplifier in this picture?
http://www.facebook.com/photo.php?fb... ... =1&theater
Re: Using two amplifiers simultaneously !!!!Help Me JOHN !!!
Posted: Tue Jan 10, 2012 11:35 am
back and forth we go back and forth...
If you do not yet have the stereo mod for any of your GCX units then you will simply use a Y Splitter cable from the last GCX loop in your signal chain to feed two amps.
If you have added the stereo mod to GCX 3, Loops 5-8, then you would use an Insert Point cable from the last GCX Loop in your signal chain to feed your two amps.
Posted: Thu Jan 12, 2012 11:11 am
by Marcus
John, just have to thank for the information.
I apologize for my lack of knowledge.
Not wanting to abuse you, you could make me a drawing showing these options you reported.
As for cables, tell me how would be the jack (between mono and stereo).
Again, I can only thank you for your help and patience.
Thank you.
Posted: Thu Jan 12, 2012 4:09 pm
It would be just like you have it but using a Y cable to feed two amps from Loop 8 of GCX#3...
The question you have to answer is, is GCX #3 modified for stereo use?
If mono you will use a Y Splitter cable with all mono ends.
If Stereo you will use an Insert Point Cable with one stereo end and two mono ends.
Posted: Fri Jan 13, 2012 5:52 am
by Marcus
I see.
So how I modified my GCX 3 for stereo, I use the Y cable jacks all mono.
Right?
Thank you my friend.
Posted: Fri Jan 13, 2012 6:20 pm
I'm afraid I am unsure what you are asking...
Is GCX #3 modified for stereo?
Posted: Mon Jan 16, 2012 12:51 pm
by Marcus
My GCX # 3 is not modified to stereo .
Posted: Mon Jan 30, 2012 7:19 am
by Marcus
HELP ME JOHN !!!!!!!
THANK YOU.
Posted: Tue Feb 07, 2012 11:11 am
Marcus... you need a Y Cable with all three ends mono.
This cable will split the mono output of GCX #3 Loop 8 out to feed the inputs of your two amps.
Posted: Tue Feb 07, 2012 12:15 pm
by Marcus
Ok John !!!!!
Thank you my friend .
