hello
someone can help me to connect this setup so that i can change the channel of the amplifier through midi? to avoid walking to change channels and turn the delay while i switch the amp chennel
i want to connect G-sharp to my GCX Guitar Audio Switcher and a midi pedalboard FCB 1010 to when i want to make some solos i only push one button and i turn on the delay and switch to lead on my amplifier
cheers
sorry for my english
marshall tsl 100 + G-Sharp +GCX Guitar + Behringer FCB1010
Re: marshall tsl 100 + G-Sharp +GCX Guitar + Behringer FCB1010
In order to use the GCX to control the Marshall's footswitchable functions you will need a custom cable. This cable will have the 6 pin DIN plug on one end that terminates out to multiple 1/4" ends. Here is a diagram someone would need in order to make this cable.
Hi - Very helpful information. We just need to know where to get this adapter/connector you have pictured.
We are also adding two more multi-channel amps to the rig (a second Marshall TSL60 and a Ceriatone Overtone HRM) Besides these two additional amps, we are thinking about using a Roland Jazz Chorus to run our guitar synth system.
MIDI devices
we are using Eventide Ultraharmonizer H3000 (XLR in and outs) and Roland SX-700 (1/4" in and outs) and TC Electronics G-Force or 2290.
What are we going to need to run all these amp channels and be able to switch in our MIDI devices in parallel?
Thank you!
EV & Sue
Paradise Sound Arts
http://paradisesoundarts.com
A single loop of a GCX or single switch of the Control Switcher will control a single function on an amplifier. There are 8 functions alone between the two Marshal amps.
JohnClark wrote:What are we going to need to run all these amp channels and be able to switch in our MIDI devices in parallel?
Thank you very much for the information, John
Sue
Hey Y'all,
Appreciate the info on this topic. I just recently got a GCX + GCP and was looking for a way to control my Marshall TSL from them. I actually took what was suggested here and did something a little different. Given the issues everyone typically has with the TSL's footswitch cable going out, I had already modded the TSL's footswitch to have a female DIN connector (instead of the cable going directly into it) and a male-to-male MIDI cable to go from the head to the modded footswitch.
So, following the suggestions on this post, I built a breakout box with a female DIN connector on one side and 4 TS jacks on the other. I followed the wiring diagram, and bingo - it all worked just fine. I've attached some pics.
- Nick
- Nick
- Attachments
- TSL GCX breakout box (4 x TS jacks)
- tsl-box-4xts.jpg (67.01 KiB) Viewed 12397 times
- TSL GCX breakout box (DIN-side)
- tsl-box-6-pin-din.jpg (60.65 KiB) Viewed 12397 times
- TSL GCX breakout box (inside)
- tsl-box-inside.jpg (83.29 KiB) Viewed 12397 times
Can you please send wiring diagram to achieve this also how has it worked since you made converter box?
