SIMPLE QUESTION: What do you use to label the GC Pro?
xmacvicar
Post by xmacvicar »
When you see stuff like this, what are people using to label the GC Pro? A label maker? Is that a permanent/hard to remove sticker?
nyteowl
Re: SIMPLE QUESTION: What do you use to label the GC Pro?
Post by nyteowl »
Those look like labels from a thermal label making device, so if that's what you're after you might want to check out a Brother P-Touch.
There are numerous models to choose from. I used a similar device from Casio in the past to print labels to identify mixer channels. The labels stayed on real well and were relatively easy to remove without leaving any residue behind.
domct203
Post by domct203 »
I made my labels in a graphics editor (CorelDRAW), printed them at my local Walgreens as an 8X10 picture, cut 'em out and stuck 'em on with 3M re-usable sticky tabs http://www.amazon.com/Scotch-Restickabl ... pd_cp_hi_3
I labeled the Wah, Volume and Boost with a P-Touch.
The big colored squares make it easier for me to see on a dark stage.
Dom
