GCP switch gone bad!
Posted: Thu Jan 10, 2013 1:08 am
by Yomko
Hey guys, one of my switches on my GCP has gone bad and stopped working.. What kind of switch would I need to properly replace it and where can I get one? Any help is appreciated!
Re: GCP switch gone bad!
Posted: Sat Jan 12, 2013 6:40 pm
by Yomko
As I try to open the unit - two of the screws on top are stripped and really tight, there is no way I can get em off... What can I do??
Posted: Mon Jan 14, 2013 6:19 pm
by a2dconverter
Hey Yomko,
You need a Dremel tool with a cut-off wheel to either
1. cut a slot for a slot screwdriver or
2. to grind off the head of the screw.
Then you need a new screw!
I hope this helps
seeya
Joe
Posted: Tue Jan 15, 2013 6:06 am
by nyteowl
I like Joe's suggestions, and would first try cutting a new slot for a flat head screwdriver. Spray a little WD-40 or something similar around it and give it a little time to sink in. That may let you remove the existing screw.
If that doesn't work, it's on to Option Two and you'll have to grind the head off.
