Pedal Switcher as A-B input switcher.
Posted: Tue Feb 25, 2014 7:40 am
by alfonso
Does anyone use it as an unbuffered alternative input using the first loop return?
Thx Alf.
Re: Pedal Switcher as A-B input switcher.
Posted: Tue Feb 25, 2014 3:15 pm
This can be done, but you will need to re-establish the ground connection that is lifted on the Return jack. This can be done externally by soldering a wire to the Sleeve of the cable plugged into the Input and connecting it to the Sleeve of the cable plugged into to the Return of Loop 1.
Posted: Sat Mar 01, 2014 7:17 pm
by alfonso
Thank You :)
Posted: Sat Mar 01, 2014 7:25 pm
by alfonso
Another question...do I find the ground also in the sleeve of send 1? In that case simply adding to my inst.2 cable a dummy jack with just the sleeve connected to be put in the send could solve my problem?
thanks again.
Posted: Tue Mar 04, 2014 1:48 pm
That should work too!
p.s. Are you switching between two instruments regularly or is this supposed to be for "emergency" use?
Posted: Wed Mar 05, 2014 7:51 am
by alfonso
JohnClark wrote:That should work too!
Thanks John,
don't do it often, but I have a gig where the pedal switch is not that necessary and I have an EH Freeze pedal and a bit of delay that I would share between an electric and an acoustic...so the possibility to have a double input and a double output in a single box, powered by my pedalpower 2+ is tempting. :)
When I switch the acoustic guitar input on I also switch the output going to the D.I. and I'm done.
