Omni Mode
mft1
Omni Mode
Post by mft1 »
does anybody know how to get into Omni Mode
I cant get my GCP to work with anything
it new so are 2 GCX nothing working any ideas
Bradshaw 4X4 orerates in Omni mode what is that and how do I setup the GCP to work it
ilovewasabi
Re: Omni Mode
Post by ilovewasabi »
i think omni mode is supposed to be set on devices that receive program changes. so depending on what kind of device you have, let's say a g major, then you set your g major to omni so it'll accept any kind of incoming program changes. you dont have to set your gcx or ground control pro to omni
Re: Omni Mode
Is GCX #1 phantom powering the Ground Control Pro? Have you enabled both GCXs within Setup Mode on the Ground Control Pro? This is covered in the Expanders section of the Ground Control Pro manual under Setup Mode.
