well i recently got all this things and im lost in space because all this midi things are new for me.
Could somebody help me and explain me how i have to make the conections to use the pedal switcher as a gcx 2?
from ground controll pro out---->pedal switcher midi in, from pedal switcher midi out->to pedal in of the gcx??.
thanks a lot.
Gcx--ground controll pro--- pedal switcher. Help please!
Re: Gcx--ground controll pro--- pedal switcher. Help please!
The order which the switchers are placed in the MIDI path dictates what number GCX they will be. so in your setup the Pedal Switcher will be GCX-1 (loops 1-4) and the GCX will be GCX-2.
Thanks for reply!
and if i want the gcx as gcx 1 and pedal switcher as gcx2 the connections will be:
ground control pro out--- pedal in gcx,gcx midi out----midi in pedal switcher???
thanks.
thanks.
rockman8812 wrote: and if i want the gcx as gcx 1 and pedal switcher as gcx2 the connections will be:
Exactly!
Thanks a lot men.
Hello!
i made a graph in the gcx worksheet because a c.a.e preamp just arrive and i want to know if this is the right way to connect this things but when i tried to upload the graph the webpage says that the document is to heavy. How can i do to show you the graph so you can see if im making right the connections??
thanks a lot a again!!
rockman8812 wrote:Hello!
I would assume that you just need to make the file size smaller by setting it for a lower resolution. How big is the file you are trying to post?
Here is the graph i made, please tell me if i have any mistake.
thanks a lot again.
thanks a lot again.
Looks good to me... how does it sound?
I dont know yet hehe. Im waiting the preamp it would be here in any moment! so i wanted to know if the connections with the preamp that i was thinking to do where good because i was insecure in how to plug the crunch and lead channel into the gcx and continuing the chain with the effects to the power amp.
THANKS a lot men!
Pd. ill would let you know when i plug all this things together to see what happens.
THANKS a lot men!
