Help a noob out!
madmax
Help a noob out!
Post by madmax »
Hi! I realize that there must probably be 100 posts like this, but Im really terrible at connections and midi and all so I was wondering if someone could help me out here.
Im trying to run everything in MIDI from my Ground Control Pro.
So far that just means channel switching my Mesa Mark IV, and selecting different presets on my Gmajor at the same time. The GCX Audio Switcher would allow me to do this, right?
Well, I only see options to turn loops on/off, so I cant understand how you can change presets on the Gmajor there for example.
Basicly, could someone just suggest me a system to control my amp channels, g major presets and a stomp boxes (on/off) all through midi (ground control pro).
I would REALLY appreciate this
Max
Re: Help a noob out!
The Ground Control Pro presets will recall patches on the G-Major and set any combination of GCX loops with a single button push. This system will provide the control you are looking for.
