I am new to MIDI and switching so I could use a lesson. I have two amps Mesa Stiletto and a Mesa Electradyne plus two cabs. I would like to run them in stereo and I would like to run both amps together.
Here is what I am trying to do:
clean/clean
clean/crunch
crunch/balls
crunch/balls with solo engaged on the Stiletto
Can I use any of the voodoo labs gear towards this application? Is this even possible? Any suggestions and help pointing me in the right direction would be greatly appreciated.
Confused.....
Re: Confused.....
A single GCX or a pair of Control Switchers (one for each amp) would be able to perform the switching functions. You can use a Ground Control Pro to control any of the switchers or a Commander to control the Control Switchers. I hope that helps.
