HEX question
wurs
HEX question
Post by wurs »
I have a Tech 21 midi moose that controlls my channel switches on my Diezel D-moll. Can I also use the Midi Moose to controll the Hex? For example channel 2 on my midi mouse turnse on the clean channel with the FX loop on, would I also be able to have it turn on a loop in the Hex?
Re: HEX question
Yes, HEX can be programmed to receive the MIDI Program Changes you are already sending.
