can Gcp and GCx switch channel on my bugera
Posted: Sat May 02, 2015 9:46 am
by king kong
I have a bugera 333xl amp head and it is not a midi amp.Can I set up my gcx and gcp switchers to change channels on my amp as well as the pedals?
Re: can Gcp and GCx switch channel on my bugera
Posted: Mon May 04, 2015 6:50 am
by nyteowl
Your Bugera uses a proprietary 7-pin DIN connector for its foot switch, so you would need to either build or buy a custom cable to connect it to your GCX or a Control Switcher.
You didn't mention how many pedals you're using, but as the Bugera foot switch has four functions, you would need to use four of your GCX Loops for Bugera switching tasks. Given that, I'd suggest you consider using a dedicated Control Switcher in conjunction with your GCX.
Posted: Wed May 06, 2015 10:08 am
We have had trouble getting accurate information on the footswitch jack wiring for Bugera amps. We currently do not have a cable to connect this amp to a Control Switcher.
Try contacting Bugera about getting the pin configuration of the footswitch jack.
