My old set up was a FCB1010 control board, Triaxis, and G-major. I had 9 presets set up on the board for 3 different guitars. Clean, Dirty and Lead for each guitar. By selecting 1,1 on the foot controller, both the Triaxis and G-major switch to channel 11. 2,2 would change both to channel 22. And so on, up to 9 of these presets. What was happening, i would come out of a lead and have to hit 1,2 or another combination to get back to a clean channel, and enter the wrong channel number sometimes. ... and all of a sudden, a Toby Keith cover we were doing just became Slayer.
I would like to have 1 button access to all of my 9 current presets on both units (midi thru the triaxis to the g-major).
My main reason for buying the GCP was so I could have 1 button access to several presets. Example:On the GCP,
(song starts) I hit button 1 - clean Les Paul, button 2, Dirty Les Paul, button 3, lead Les Paul, then back to button 1 for clean Les Paul. (song ends)
4,5,6 would be for the Strat, 7,8,9 for the Telecaster.
Is this possible with the GCP, and can I program those buttons to use the same channel numbers already assigned in the triaxis and g-major?
GCP + Triaxis + G-Major Help ....... Can this be done?
Re: GCP + Triaxis + G-Major Help ....... Can this be done?
A Ground Control Pro preset can control up to 8 MIDI devices per preset... these two will be no problem. You can even assign your devices to go to differing numbered patches so you do not need to do a bunch of mapping on your processors. With 10 Presets per bank you will never need to press more than one button at a time to access your 9 presets. You still can turn Toby Kieth into Slayer... but now without missing the beat!
I doubt though that you are forced to use the FCB1010 in this "type the preset number" mode. If you dig a little deeper into the manual, I bet you will find the ability for single button access to your devices patches.
