User manual dosent seem to tell me how to....
Quinnc
Post by Quinnc »
Actually set up my presets!
Im running an amp with two channels and just a bunch of pedals with a GCX/ground control pro.
Now IF I go to the first bank and select the first present it says that I can assign what midi patches and such for it to hit when i press this preset, but more importantly it says i can assign which LOOPS ARE ACTIVATED!!! and when i hold edit to set it up none of that shows up... all that I can do is name the present, assign a expression pedal, and save it.... how can I assign what loops for that present to be associated with if they arent in that menu?
Re: User manual dosent seem to tell me how to....
You must first tell the Ground Control Pro that you have a GCX connected. This is explained in the Expanders section of the Ground Control Pro manual under the Setup Mode heading. Setup Mode is where you configure the Ground Control Pro to your particular rig. Let us know if you have any more trouble.
